Help identify this
Discussion in 'The Projects Forum' started by edpdx, Aug 4, 2010.
  1. edpdx
    Aug 4, 2010
    I pulled a diode off of a military vehicle's horn relay. They were taped together (the diode and relay, not the relay and the vehicle ;)) but I managed to get the number off of it: 1N8377. I tried a search; but it came back with only a vague NSN number and no details.
    Is this enough info to to get a replacement part. I want more of these- or at least diodes that offer the same circuit protection.
    Any suggestions on what else I can use?
  2. marshallf3
    Jul 26, 2010
    2,358
    201
    How was the diode connected to the horn?
    My guess is it's nothing more than a common rectifier used in the same way we put them across relay coils to quench back EMF spikes. In that case a 1N400x, 1N54xx, 1N56XX or virtually any common rectifier is going to work.
    Many horns are nothing more than a glorified buzzer - coil + interrupter contacts.
    If the writing is smudged a 1N3377 exists but it's a large 200A device.
  3. edpdx
    Aug 4, 2010
    marshallf3, yes the design, I believe, was to keep the circuit safe when the horn circuit reopened. It was wired into the harness; but I found a website discussing use of a similar diode, 1N4003, across the relay on a BMW bike. So your answer seems to be in sync with that article and that is good enough for me. I'll pick some up. Thanks,
    Ed
  4. JoeJester
    Apr 26, 2005
    3,388
    1,211
    The manufacturer was Catapillar.
    NSN: 5340-01-306-8913
    CAP, PROTECTIVE, DUS
    Part No: 1N8377
    Obviously not the part you were thinking about.
    A 1N5377 is a 91V 15A zener diode. What size is the diode ...close to a 1N4xxx?
