Help identify this power mosfet
Discussion in 'Electronics Resources' started by bobbyrae, Dec 28, 2010.
  1. bobbyrae
    Thread Starter Active Member
    May 14, 2009
    42
    Obviously the brand is ST. But the blast from the capacitor that went bad burned a spot on the model number! My first guess is STW11NB80. It is a TO-247 package.
    For your info, it comes from an ATX PC power supply made in 2003. 480 watts.
    Any other possibilities? If that's it, the next step would be to find an equivalent replacement since it is an obsolete part.
  2. retched
    Dec 5, 2009
    5,201
    313
    Is that the only one on the board?
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
  4. bobbyrae
    May 14, 2009
    42
    It's really tight in there. There are 2 heat sinks with similar components bolted onto them. At least 4 other transistors. I can't tell what they are without taking a lot of stuff out. If you are suggesting that I replace ALL of them, well... that would be VERY hard. And there is no evidence that the others are bad.
    If you suggesting that there is another that would be identical... OK, that's a thought I had too, but like I say, it is so tight in there you just can't see those things without taking a lot of stuff out first. The one that looks like it might be the same is on the other side of the heat sink and right up against the main transformer. The transfomer would have to be removed and that looks like at least five solder points.
    In a way I am lucky that it failed the way it did because all the failed stuff (fuse, caps, transistor) were easy to get at.
  5. retched
    Dec 5, 2009
    5,201
    313
    I was just suggesting reading the number off a similar MOSFET.
    The B80 is all over ST's website.
    Its a 55v 80A jammie, from what I can tell.
  6. bobbyrae
    May 14, 2009
    42
  7. bobbyrae
    May 14, 2009
    42
    Really? All I get is "no such product exists!" when I search at the ST site, So could you give a link? I found the datasheet at other places like Digikey. But it's an 800V, 11A power MOSFET, not a "jammie".
  8. retched
    Dec 5, 2009
    5,201
    313
  9. thatoneguy
    Feb 19, 2009
    6,357
    718
    No, that doesn't work. for me (no cookies)
    To the OP: a 2003 Power Supply won't be much use if you upgrade your motherboard or video card. You may be better off upgrading and getting speedy processor and graphics with a new power supply. A new supply that size is around $40 or less.
  10. bobbyrae
    May 14, 2009
    42
    Please take a look at the photo. The model number starts with STW1 and ends with B80. So it is STW<missing digits>B80, which clearly does not match anything in the link you gave.
    And I have no idea what is meant by "jammie".
  11. bobbyrae
    May 14, 2009
    42
    I didn't start this discussion to consider computer upgrade options. Of course you can always find cheapo power supplies! So what? That is not what we are talking about, OK?
