??? Should read very high if a MOV.Thanks,
Visibly it is intact, and the resistance measures out at 0.0 ohms.
Disc ceramic capacitors that look like that, generally have various standards symbols marked on them as they're typically used as mains input filters, and sometimes straight across the mains before the switch.Thanks,
Yes.. a little 'Reverse Engineering' of the associated components or immediate circuit maybe?To narrow it down for sure, a bit of detective work is in order, develop a context for that part.
Quis custodiet ipsos custodes?A moderator was reported to a moderator. So who's the Senior.
That could have caused a infinite loop and brought the forum to it's knees!A moderator was reported to a moderator. So who's the Senior ?
Custodiet ipsos Custodes sample survey.Quis custodiet ipsos custodes?
But to the OP. Can you tell more about what kind of circit this component came from
I think he used the Loosewire versionYou need a better translator...
Veritas odium paritCare to tell me without bringing loosewire into this.
I think he can translate better.
