I have some bad capacitors in a 2Wire router that I'd like to fix. They are aluminum electrolytic SMD caps that have a "K" outline on their tops that lead me to believe that they've gone bad. One of them has the following markings: E55 470 10v I take it as a 470uF rated at 10 volts. The other is harder and I've scoured for nomenclature that doesn't seem to fit the markings: 551 1500 6z Both of these capacitors are the same size. E55 has a green quarter semicircle along its left-hand side while 551 has a black quarter semicircle if it is significant. Thanks for any insights that any one may provide.
