Help Identify Temperature Indicator/Controller
Discussion in 'General Electronics Chat' started by joeyd999, Dec 7, 2011.
  1. joeyd999
    Thread Starter AAC Fanatic!
    Jun 6, 2011
    2,757
    2,926
    Hi, Guys.
    I am trying the find the manufacturer of and data sheet for a temperature controller. I have absolutely no info on it whatsoever. Attached are pics.
    If it help, the panel cut out is about 2.8" x 1.1". The bezel size is 3" x 1.4". The unit is about 2.4" deep.
    Thanks in advance.
  2. strantor
    Oct 3, 2010
    4,302
    1,989
    yeah that's cheap china. I worked on some machines a while back that had displays like that (not temp displays, but same front panel).
    The name on the front panel is a rip off of another company
    where did you get it?
  3. joeyd999
    Jun 6, 2011
    2,757
    2,926
    I am trying to source it for a customer. He doesn't know where it came from. I *really* have no additional info except for the photos I posted. Honest!
  4. strantor
    Oct 3, 2010
    4,302
    1,989
    well I would source something a little better. You probably could not find that if you tried.
    http://www.alliedelec.com/search/se...rchType=0&Term=1/8+din+temperature+controller
    http://www.newark.com/jsp/search/br...mperature+controller&Ntx=mode+matchallpartial
    http://www.google.com/search?q=1/8+din+horizontal+temperature+controller&hl=en&tbm=shop&aq=f
    http://www.ebay.com/sch/i.html?_fro...perature+controller&_sacat=See-All-Categories
    http://www.omega.com/toc_asp/subsectionSC.asp?subsection=P04&book=Temperature
    http://www.omega.com/toc_asp/subsectionSC.asp?subsection=P02&book=Temperature
    if you absolutely MUST have THAT meter, contact Applied Industrial. That can find anything. if they can't, you don't need it.
