help id trim pot
Discussion in 'General Electronics Chat' started by 1-3-2-4, Feb 21, 2013.
  1. 1-3-2-4
    Thread Starter Active Member
    Dec 26, 2008
    194
    I'm going to take a guess and say it's a 100k potentiometer? If so what is the adjustment range on it? I can't find any specs or links.. the clear turn part says "HDK" but that's all.
  2. ErnieM
    Apr 24, 2011
    7,443
    1,628
    While it is hard to tell from the incredibly tiny images posted yes this is indeed a 100K pot from the 104.
    You can adjust it between zero and 100K. You get about 3/4 turn to cover that range.
    1-3-2-4 likes this.
  3. mcgyvr
    Oct 15, 2009
    4,793
    976
    when in doubt bust the multimeter out.
    Then count the number of turns it takes for full scale.
    1-3-2-4 likes this.
  4. 1-3-2-4
    Dec 26, 2008
    194
    Thanks guys
  5. gerty
    Aug 30, 2007
    1,154
    304
    Place your ohmeter across the two outside pins to read the pot value. Place meter from center pin to either outside pin to see if value changes when screw turned.
