Help ! I need a large decoder ( 7 to 128 )
Discussion in 'The Projects Forum' started by natrix, Apr 27, 2009.
  1. natrix
    Mar 24, 2009
    7
    Hello ;
    I have a big project that has a 7 input lines ( binary value ) and the output is the line which correspondes to this value ,
    i.e if the input is 0000010 the line number 2 will be high (1) and so on .
    Can anyone help .
    Please :)
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Do you really want to decode the 7 bits to 128 single lines?
    In what do you want to make it Cmos or TTL?
    Greetings,
    Bertus
  3. natrix
    Mar 24, 2009
    7
    Yes I want a 7 to 128 decoder or any thing else can do the same process
    and I want a TTL decoder
    thanks for passing by :)
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    You can use a couple of 74154's.
    Here ia an example:
    Pins 18,19 and 20 of the High bits decoder should go to ground.
    Greetings,
    Bertus
  5. natrix
    Mar 24, 2009
    7
    thanks alot
    I'm going to try it
    but I wish if someone has an easier ideas or something .
