HELP I am looking for a ....
Discussion in 'The Projects Forum' started by dociledragons, Oct 18, 2013.
  1. dociledragons
    Oct 6, 2013
    8
    I am in need of a Dimmer for a heating pad. I no my way around electronic "if" I have a schematic. All I need is a simply schematic for a dimmer or step dimmer for A 120V heating pad. I don't want to use resistors as it isn't financially beneficial.
    Note: The goal is 2.00 or less in cost. Otherwise I would just purchase a dimmer from home depot or something.
    edit: I keep seeing these http://www.electronicecircuits.com/electronic-circuits/filament-light-dimmer-circuit will that work??
  2. crutschow
    Mar 14, 2008
    13,505
    3,376
    Probably. But you likely can't make it for 2.00 (of whatever currency you are using) unless you have a well-stocked junk box.
  3. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    As long as the load is less than the rated 4 amps of the BT136.
    Max.
