Help getting PCBs manufactured
Discussion in 'The Projects Forum' started by boriz, Nov 30, 2009.
  1. boriz
    Jul 16, 2009
    48
    Suppose I want some small (5cm square) prototyping boards made, something like this sort of thing: http://www.wa5vjb.com/images/Small%20Proto%20Board.JPG , with holes along every track, and copper only on one side, but to my own design. Suppose I want (say) 10 or 20 for the initial order, but possibly many more later. Suppose I want them cheap cheap cheap.
    Who do I call?
    I already tried ExpressPCB and the quote for 20 is outrageous.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Try BatchPCB.com
    It might take a month for your boards to get there, but they will be about as cheap as you can get.
    Fast, good, cheap. Pick two.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    I buy that exact layout routinely from Tanner's for around $2.50.
    I liked it enough to put it on my PaintCAD.
  4. ericwertz
    Member
    Aug 26, 2009
    14
    BatchPCB would be perfect, if you wanted to pay $10 each for them. BatchPCB is great if you want exactly *one* of a board, or less than about 10-12 sq.in. total.
    You could probably get 20 made for $50 + ~$5 shipping at Seeed Studio.
    http://www.seeedstudio.com/depot/fusion-pcb-2-layer-5cm5cm-max-p-513.html
    Clearly Bill's suggestion is the best if that board works for you.
  5. spacewrench
    Member
    Oct 5, 2009
    58
    The local (Portland, Oregon) Dorkbot group runs occasional PCB group orders. We're doing one now, with a price of $3/square inch for 3 copies of your board, plus $2 for snail-mail postage. If you have Gerbers ready to go, check out the recent messages on the mailing list http://http://music.columbia.edu/pipermail/dorkbotpdx-blabber/ for information about whom to contact.
    I got some boards done through the first trial batch and they came out great.
  6. ke5nnt
    Mar 1, 2009
    384
    15
    Nobody else said it, and I can't help myself...
    GHOST BUSTERS! :rolleyes:
  7. boriz
    Jul 16, 2009
    48
    Thanks all.
    I should have mentioned that I’m in the UK. Therefore, postage from USA could be a deciding factor. A cheap UK manufacturer would be best, but I figure the cheapest option is to deal direct with a Chinese manufacturer. Any ideas?
    I’m designing some small protoboards for the hobby microcontroller market. Until I’m sure they will actually sell, I’m not going to order more than say 10 or 20 in a batch. This could limit my options because the economies of scale won’t kick in until I have some turnover and can place larger orders. But I’m certainly not going to risk being left out of pocket with 200 unsellable boards.
    Free board offered for information leading to a deal. :)
