Help function generator...
Discussion in 'The Projects Forum' started by JonnyP, Mar 7, 2013.
  1. JonnyP
    Mar 6, 2013
    I need some function generator help in AC bridge circuit.
    First of all sorry for any English mistake, as it is not my native language.
    First post here and I expect not to be the last. Just found this forum in google.
    Just some background… I work as a researcher in a laboratory at my University. My main focus application in eddy current testing (http://en.wikipedia.org/wiki/Eddy-current_testing).
    So let´s go. The main focus of eddy current testing is using coils interacting with conductive materials to measure a variation of characteristics of those materials. I am using an AC bridge circuit to measure difference of two identical coils as can be seen below:
    Everything is going well except that when I connect the AC generator to the bridge circuit (the coils have ~50ohm and I used another 50ohm resistor and a trimpot to balance the bridge) I see that the voltage amplitude of the sine wave drops. So I am supposing that the circuit is draining more current than the AC generator can supply, which can damage the equipment (I´ll post all my assumption, to show all my steps, please correct If I am wrong at any part!).
    So I made a non-inverting buffer using a LM324, which works well while disconnect from the bridge, but when I use the output of the buffer to feed the bridge the sine wave become all fuzzy. And now I am stuck at this point… I need a circuit that feeds the bridge without damaging the AC generator. Can you help me?
    Just some more data:
    - Frequency of the sine wave: 5-30 kHz
    - Amplitude of the sine wave: 4 volts peak-to-peak.
    Thanks in advance!
    []´s
    João Rocha – UFRJ - Brazil
  2. Ron H
    Apr 14, 2005
    7,050
    657
    What is the inductance?
  3. JonnyP
    Mar 6, 2013
    It is about 6mH each coil.
  4. MrChips
    Oct 2, 2009
    12,646
    3,458
    You need a power amplifier, something like an LM675.
  5. JonnyP
    Mar 6, 2013
    Thank you! With this chip the only modification that I must do is not to use as buffer, but decrease the amplitude of the input signal and have a gain of 10 or more in the op amp, right?
