HELP - FunBrain Magician on Logic Works
Discussion in 'The Projects Forum' started by Ali Akbar, May 18, 2015.
  1. Ali Akbar
    May 18, 2015
    I need help with my project.
    Here are the details. I need to implement it on logic works.
    The FunBrain Magician is game that will pick a secret number between 0 – 31. User guesses what number it is. If the guess is high or low, FunBrain will give a hint.
    User will ask the magician to generate the random number by setting input GRN = 1. Magician will take the guess after every 4 cycles. If the answer is correct CA will be set to 1, otherwise H or L will be set accordingly. In the end magician should tell in how many turns user is able to guess the correct number.
    Input
    Clock Pulse CP
    Generate Random number GRN
    Guessed Number C0…C4
    Output
    Correct Answer CA
    Number of guesses D0…D4
    High H
    Low L
  2. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,685
    1,297
    I don't understand the question. Is this a programming project or a hardware design? What have your done so far?
    ak
  3. MrChips
    Oct 2, 2009
    12,624
    3,451
    Do you know what is meant by successive approximation? This is also call a binary search algorithm.
    For a number between 0 and 31, the most number of hints required would be 5.
    For a number between 0 and 255, the most number of hints required would be 8.
