That's why I told him to switch off half the transformer in post #23, drawing 1It will never come close to delivering 5A when the output is adjusted down to 1.25V.
Your best option is to tell us that about 39 posts ago. How many people do you think are going to start over now that you changed the design to an electrolyser instead of a power supply?I don't really need 5 amps neither going down to 1.25v. So what's my best option with what I have?
That's why I want a power supply to find that!What voltage and current do you normally use when doing electrolysis?
Well I need a power supply, thats why I'Ve posted this... I've bought the new transformer like you've told me...That's why I told him to switch off half the transformer in post #23, drawing 1
That will get the power down to 60 watts and the thermal resistance budget is about 0.26 C/W case to ambient or 3.79 W/C
That's a finned heat sink about 8 inches by 12 inches and an inch thick without a fan.
I guess this one is going to need a fan or forget about dialing the voltage to 1.25 volts and trying to get 5 amps out of it.
Exaclty he wants to separate the oxygen and hydrogen from water!Then you may need more current, what are they metal plating, or just separating oxygen and hydrogen from water?
Is he trying to blow himself up, or get better gas mileage???Exaclty he wants to separate the oxygen and hydrogen from water!
