Help for voltage regulation
Discussion in 'General Electronics Chat' started by yasinji, May 15, 2014.
  1. yasinji
    Mar 25, 2009
    12
    Is there any device or component that can clamp the 200V input to 25V for 200ms:mad: without failure? Please help.
  2. pwdixon
    Member
    Oct 11, 2012
    488
    56
    Obviously yes but the problem is that your question is too general to actually be able to make sensible suggestions. More details required on your application/current circuit please.
  3. yasinji
    Mar 25, 2009
    12
    This voltage is used for taking measurement. The voltage varies for 0.5V to 200V. The voltage is created on a coil(inductor) due to induced emf when a current flows through a primary conductor using Faraday's current law..The voltage above 25V is due to fault current in the primary conductor which I dont require to measure. So from 0.5V to 25V I want the actual voltage and above 25V to 200V I want the voltage to be clamped at 25V.
    I dont know much theory nor I am a professional on this design its just trial and error. Can anyone help to find a component which can do my job? Please help!!!
  4. t06afre
    May 11, 2009
    5,939
    1,222
    Do you have any schematic or diagram for this setup. More details are needed. Do you want to clamp the output just for measurement? That may simplify the the setup
  5. Stuntman
    Mar 28, 2011
    189
    50
    Varistors and/or TVS diodes come to mind.
    As mentioned, specific information about what kind of current you will be fighting will help in selecting specific components.
  6. crutschow
    Mar 14, 2008
    13,475
    3,362
    What is the inductance and the current value?
  7. #12
    Nov 30, 2010
    16,665
    7,310
    That is the critical question.
    If you are only dealing with milliamps, the circuit can be clamped with a simple zener diode. More than that amount of current and the components must be larger.
  8. inwo
    Nov 7, 2013
    2,435
    315
