help for this circuit number C8051F226DK
Discussion in 'Programmer's Corner' started by jason1987, Jun 3, 2009.
  1. jason1987
    Jun 3, 2009
    7
    hello everyone can someone help mi, using a variable resister to control the LED dimmer.. using silicon software to write a program using ADC and PWM to control the LED dimmer.. anyone can help?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Please stop doing multiple postings of this question.
    "Silicon software" is essentially meaningless. Google finds references, but none that seem to pertain. Can you explain in some detail what it might be?
  3. jason1987
    Jun 3, 2009
    7
    the hardware i was given a variable resister and i hv the circuit diagram.. can help mi take a look at it? at i need to write silicon software to write a C languang.
  4. Arm_n_Legs
    Mar 7, 2007
    183
    10
    You are using the Silicon Lab C8051F226 microcontroller which is a derivatve of the 8051. You are to write the program in C, not using Silicon Lab sofware, but using Keil C compiler. You need to know how to ask the question properly.
  5. jason1987
    Jun 3, 2009
    7
    reply mi.. doing ADC n PWM generate a led dimmer
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That is a manual for the prototyping board. Have you been able to design an interface for the LED dimmer? I would not think that the D to A converter was particularly well suited to doing PWM.
    Do you understand the principle of PWM?
  7. jason1987
    Jun 3, 2009
    7
    wat is the principle of PWM?
  8. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It sounds as if you need to do some research before getting started. Pulse width modulation is a means of controlling averave current through a train of pulses with a variable width - http://en.wikipedia.org/wiki/Pulse-width_modulation
    As you will see, the ADC (understood as Analog to Digital Converter) may not play a part in doing PWM to control a LED.
    However, used with a photosensitive device, the ADC can provide a control input to allow intensity control through a program loop.
  9. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Hey Jason1987 good to see you're here too. Guess you're having the same luck here getting someone to do your homework assignments for you.
  10. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Is it time to consider a switch to Art History?
  11. millwood
    Guest
    you can. you can use a trimmer to generate an analog signal, use the adc to convert the analog signal to get a digital reading of the wiper's position, and use that to control how long you want a port to be set, or cleared. viola! you have your own pwm.
    i have a little program that does precisely that.
  12. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    To jason1987 - Beside trying to ask the same question again, what progress have you made? Do you understand how a PWM signal is generated yet? How about the hardware between the uC and the motor?
  13. jason1987
    Jun 3, 2009
    7
    i haven nt do anyting yet cos i am searching.. can guide mi? pwm wrk
  14. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Since Art History requires research I don't think it would be an ideal course choice.
    A simple Google search provides buckets of PWM info.
    http://lmgtfy.com/?q=PWM
