Greeting guys, I just bought a Solenoid Valve which the model is STNC Model: TG2521-08
link : http://www.made-in-china.com/showro...rsvBLCki/China-Solenoid-Valve-TG2521-08-.html
There's problem arised here, this solenoid valve is to be controlled by a controller board. I need to make sure that the voltage connection of the solenoid valve is correct... As it has Earth, Neutral and Live (attached photo). I wanna know the Live wire should connect to which pin, is is the pin with the Positive sign and the neutral wire connected to the other pin, as I know the top pin is for earth and is not needed to connect rite? Seriously thanks for helping guys. Really need you guys help !
