Help for my heart rate monitor
Discussion in 'The Projects Forum' started by ddickey, Feb 21, 2012.
  1. ddickey
    Sep 28, 2011
    55
    Finally got teh circuit together but I can'tget it to work. I replaced the photo diode and the ir diode with the TCRT5000. I'm getting 1 volt across the TCRT5000. I think there is something wrong with this component, also I can;t get the led to light up with each heart beat. So any suggestions on how to test the optical sensor? Thanks
  2. Felo
    Member
    Feb 20, 2012
    91
    13
    Hi, I can't really see where everything is going here, can you post a schematic??
  3. ddickey
    Sep 28, 2011
    55
    oh yeah, here they are.
  4. ifixit
    Distinguished Member
    Nov 20, 2008
    639
    110
    Hi ddickey,
    You need to make a few changes before the circuit will even work at all. See attachment. You have to bias the amps so that the output swing is between +5 and grd.
    I have not tested, but it should work now, however, you may need to adjust gains and cap values to get what you want on the output.
    Good Luck,
    Ifixit
  5. ddickey
    Sep 28, 2011
    55
    Excellent. I'll rebuild the tonight.
