help for my assingment ?
Discussion in 'Homework Help' started by ubeyd, Nov 30, 2014.
  1. ubeyd
    Nov 30, 2014
    Hi
    i am a student of computer engineering but my college so insisted to teach me physics :p
    so i have an assignment..i think questions are pretty easy but i am stuck at few points
    so at first question i know how to find the voltage drops if there is only voltage source but there are 2 in this question so any tips ?
    and for the second part, i am familliar with KVL but again 2 voltage source so i am not sure how it effects the answer.
    about the second question i take any advice cuz i am not familliar with Thevenin equivalent yet
    thanks in advance
      File size:
      167.1 KB
      56
  2. ubeyd
    Nov 30, 2014
    i just need some tips come on guys
  3. dalam
    Member
    Aug 9, 2014
    58
    6
  4. MrChips
    Oct 2, 2009
    12,624
    3,451
    Well guess what?
    You cannot become a competent engineer if you do not know physics and math.
  5. Jony130
    Feb 17, 2009
    3,990
    1,115
    Q1 - simply try applying KVL around the loop you have in the circuit.
    Q2 - use a circuit theory and find Vab voltage, and Vab = Vth, next short A and B together and solve for Isc.
    And finally Rth = Vth/Isc.
    For example we could find Vth by using the superposition for I current.
    I = 10V/(2000 + 200) - 9*I * 200/(2000 +200)
    I = 10/2.2 - 9*I*0.2/2.2
    2.2*I = 10 - 9*I*0.2
    2.2*I = 10 - 1.8*I
    4*I = 10
    I = 10/4
    I = 2.5 and this result is in mA
    I = 2.5mA
    So Vab = Vth = 10V - 2.5mA*2000 = 10V - 5V = 5V
    http://forum.allaboutcircuits.com/threads/thevenins-theorem.102247/#post-771380
      File size:
      56 KB
      34
  6. ubeyd
    Nov 30, 2014
    Thank you so much ! you are a life saver
  7. dalam
    Member
    Aug 9, 2014
    58
    6
    In the circuit that you uploaded if I take Vb as a reference node then Va becomes zero.
    I1=0. And I=10/2000. Isc= 10*I=1/20.
    What is wrong in this analysis?
  8. Jony130
    Feb 17, 2009
    3,990
    1,115
    Nothing is wrong, Isc is equal to 1/20 = 50mA
    So tell me why you think that your analysis is wrong ?
  9. dalam
    Member
    Aug 9, 2014
    58
    6
    V/2000+V/200=9I+1
    I=-V/2000
    So, V/2000+10V/2000=-90V/2000+1
    101V/2000=1
    V=2000/101
    V/I(test source=1A)=Rth=2000/101
  10. dalam
    Member
    Aug 9, 2014
    58
    6
    You got I =2.5mA that's why. Moreover I did not understand how did you use superposition here.
    Can you please testify the answer that I posted in the post above and the approach as well.
    Thanks in advance.
  11. Jony130
    Feb 17, 2009
    3,990
    1,115
    Please check your math again because the correct answer for V is 100V
    And Rth = 100V/1A = 100Ohm
    http://www.wolframalpha.com/input/?i=V/2000 +V/200=-9V/2000 +1
    I got the same result using different approach.
    Vth = 5V and Isc = 50mA so Rth= 5V/50mA = 100 Ohm
    Where I wrote that Isc is 2.5mA ??
    In my post 5 I solve for Vth, but I use superposition to find I current first.
    What you do not understand. I simply use a superposition to find "I" current
    First I remove current controlled current source from the circuit.
    So I' = 10V/(2000 + 200)
    Next I remove 10V voltage source and use a current divide rule.
    I'' = - 9*I * 200/(2000 +200)
    and finally
    I = I' + I'' = 10V/(2000 + 200) - 9*I * 200/(2000 +200)
    Also please read this
    http://forum.allaboutcircuits.com/t...rrent-and-voltage-sources.101488/#post-764893
  12. dalam
    Member
    Aug 9, 2014
    58
    6
    Thanks a lot. My bad, I wrote -90V/2000 instead of -9V/2000. And thanks for explaining about superposition. I was not sure weather dependent sources can also be analysed using superposition.
  13. WBahn
    Mar 31, 2012
    18,085
    4,917
    Yes they can. As long as the circuit is linear, superposition applies (in fact, that is the definition of a linear system).
    Imagine that you have a current I0 that is a function of three different independent sources:
    I0 = I1 + I2 + I3
    Now imagine you have a dependent source that is
    Ix = kI0
    Well, that works out to
    Ix = k(I1 + I2 + I3) = kI1 + kI2 + kI3
    and so we see that it is the sum of the currents that are output by the dependent source in response to the three independent sources individually.
  14. dalam
    Member
    Aug 9, 2014
    58
    6
    Thank you, WBahn for helping me out.
