Help for Helical Antenna design for tv reception in the philippines
Discussion in 'The Projects Forum' started by Lyarad_13, Oct 8, 2013.
  1. Lyarad_13
    Oct 8, 2013
    i hope you can help me guys, we are tasked to build a helical antenna that would have a good reception for channel 2 (54-60 Mhz). Our main problem is on how to minimize dimensions. a 54 Mhz would have 177 cm diameter and 3.34x10^3 cm in length. Hope you can help me with this guys. tnx
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Why do you want to build a helical antenna?
    Here is a calculator for it:
    http://www.vk2zay.net/calculators/helical.php
    A 54 MHz helical would need a reflector dish of about 5 meters in diameter.
    Here are some pages with other antenna types:
    http://educypedia.karadimov.info/electronics/antennas.htm
    http://educypedia.karadimov.info/electronics/antennatypes.htm
    http://educypedia.karadimov.info/electronics/antennatypeslist.htm
    http://educypedia.karadimov.info/electronics/antennayagi.htm
    There is also a hamamateur page with a lot of antennas:
    http://ac6v.com/antprojects.htm
    Bertus
  3. Ramussons
    May 3, 2013
    562
    92
    TV signals are normally broadcast in H Polarisation. I would prefer to design a Multi Array Folded Dipole for that frequency.
    Ramesh
