Help for brushless dc card
Discussion in 'The Projects Forum' started by jm-a, Nov 26, 2011.
  1. jm-a
    Thread Starter Active Member
    Oct 20, 2010
    105
    Hi all,
    First thanks for your previous helpfull advices :) .
    340V and 15V power supply work fine.
    Now , third step in order to use my brushless milling machine, - I hope of course .....
    I'd like to get advices from experienced members about the following draft; in fact , i got the initial drawing and replaced components.....
    Surely mistakes,of course.....
    A question about powering hall sensors:
    In MC33035 datasheet, pin 8 ouput is 6,2 reference voltage for these items.
    I added 5V power supply with 7805 for hall sensors ,and also for a power on led on casing, is this a good idea?
    Second question:
    What power needed for IGBT resistors, 1/2 ,1 or more watt?
    Datasheet.zip is for MC33035 , MC33039 , FOD3120 and MEA1509SC
    Schematic is the draft made with Kicad.
    Numérisation0003-modif-1FINAL.jpg is the initial drawing.
    Thanks a lot as usual.
    jm
