Help for Battery datasheet
Discussion in 'General Electronics Chat' started by sudharshan.panduranga, Oct 17, 2008.
  1. sudharshan.panduranga
    Thread Starter Active Member
    Apr 10, 2008
    61
    Hiii.....
    Can anybody suggest me to calculate the Rechargeable battery life.
    Am using 3.6V 600mAh rechargeable battery.
    Or is there any website for battery datasheet????
    waiting for the reply
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Can you share the manufacturer and their part number?
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    It might be a Ni-Cad or it might be a Ni-MH battery. Do you know which type it is?
    They can be recharged "up to" 1000 times.
    If they are overcharged then they are doomed to a short life.
    www.energizer.com have a datasheet for every battery that they make (do they make batteries anymore? Mine are stamped "made in Japan").
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    This is not good!
    I do not know what the model of your battery is.
    If you try to charge it without information, not good.
    Deep sorrow.
    Wrists at risk.
  5. sudharshan.panduranga
    Apr 10, 2008
    61
    Battery make- Panasonic
    P-P501
    KX-A36
    3.6V 600mAh
  6. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    300 to 1000 charge/discharge cycles, depending on load and degree of discharge.
  7. Audioguru
    Dec 20, 2007
    9,411
    896
    It was an old fashioned Ni-Cad battery. Most manufacturers don't make Ni-cads anymore. They make Ni-MH ones with a much higher capacity, maybe 2500mAh which is 4.2 times more.
