Help for 3 phase inverter project to change 24V DC to 120V AC
Discussion in 'Homework Help' started by circuitbird, Oct 21, 2015.
  1. circuitbird
    Oct 21, 2015
    Hi all
    I'm trying to design a 3 phase inverter to change 24V DC to 120V AC and wondering how should i start
    this is my first project so it will be great if someone can help me out
  2. GS3
    Sep 21, 2007
    408
    35
    You want to *design* a converter from 24 Vdc to 120 V ac, 3 phase? I would not recommend such a project to a beginner.
  3. DickCappels
    Aug 21, 2008
    2,758
    667
    You should start by detailing your requirements; output power, regulation, harmonic distortion, etc. After that, try making a single phase converter and get that working before bothering with a full three phase converter.
  4. circuitbird
    Oct 21, 2015
    But I'm assigned to do that project
    Any help would be appreciated
  5. GS3
    Sep 21, 2007
    408
    35
    You need to define your requirements but, in any case, this is definitely not a project for beginners.
    A 3 phase power supply is going to be something handling serious power capable of running motors and other big loads.
    Your household inverter has a FET H bridge but for inductive loads you are going to have to seriously redesign it for inductive loads.
    Then you will need to have three separate inverters with a single control unit which switches them 120º apart.
    Plus protections, etc.
