Help finding most simplified POS expression using Karnaugh Map
Discussion in 'Homework Help' started by Guest32, Jan 26, 2012.
  1. Guest32
    Jan 24, 2012
    5
    Hi everyone,
    First off, thank you for the help from my 1st post. I am doing my next homework assignment and have the following problem:
    _________________________________________________
    Use a Karnaugh map to find the most simplified POS expression for F given
    F = A'BD + C'D' + A'CD + A'BC'+ABC'D'
    I am not required to show all the steps, so I used an automatic Karnaugh map program and had it solve it for me. Here is what it gave:
    F = (B+D') (B'D) (A'+B)
    = (B+D')
    = (B'+D)
    = (A'+B)
    This is the first time I have used a program like this, and I'm not sure I understand the way it is expressing the answer. Is it telling me that the final answer is F = (A'+B)? Can someone verify this for me please?
    If it helps, and hopefully I am correct, here is how I drew my Karnaugh map:
    1 0 0 1
    0 1 1 0
    0 1 1 0
    0 0 0 0
    I am not sure how to verify this since I am doing this for the first time. Hope to hear from someone!
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    You have mistyped the second sum. It is (B'+D).
    What your software is trying to tell you is that F=(B+D') (B'+D) (A'+B) and that product contains the sums (B+D'), (B'+D) and (A'+B).
    Guest32 likes this.
  3. Guest32
    Jan 24, 2012
    5
    Ok, thank you so much! I'm glad I found this site, you guys are very helpful! I'll probably be here again next week with new questions :D
  4. joeyd999
    Jun 6, 2011
    2,757
    2,936
    You may want to consider dumping the software and actually learn how to do this yourself. The problem you stated is elementary.
    Someday, there may be a cataclysm and your 'tools' will not be available to you. Your brain will then be the only tool available. Learn to use it. :)
    Guest32 likes this.
