Help finding missing component values
Discussion in 'General Electronics Chat' started by lokeycmos, Feb 24, 2013.
  1. lokeycmos
    Thread Starter Active Member
    Apr 3, 2009
    432
    7
    on the attached pic of an ignition coil driver R and C need to be determined so that the inductive kick will be below the maximum safe voltage of about 400V for a IRF740 MOSFET. The frequency wont be fixed at 300hz as in the example. my question is, what would be some good starting values for R and C. how would i go about calculating these? i know it says to experiment, but im looking for a ball park value to start with. Thanks
    i actually have 3 ignition coils here are primary specs if you need it:
    1) 6.7mH 1.5Ohm
    2)5.9mH .8Ohm
    3)6.8mH 1.5Ohm
  2. #12
    Nov 30, 2010
    16,704
    7,352
    First, I'd lower that TVS to a hundred volts.
    Second, are you going to let these coils go to 70V/ DC resistance?
    1/2 CV^2 = 1/2 LI^2
    for 5.9mh, 87.5 amps, 45.172 = CV^2
    to set the capacitor voltage limit at 100 volts, 4517uf at 100V
    You can mess around with a 200V TVS or a 300V TVS and alter the capacitor charge that way. You should add a resistance between the catch capacitor and the drain of the transistor to avoid di/dt = infinity.
    I lost my formula for inductance and time. The short "on" time might be enough to reduce the current from maximum.
    You can also look here for ideas.
    http://forum.allaboutcircuits.com/blog.php?b=478
