Help finding a M0265516 transistor
Discussion in 'General Electronics Chat' started by Michael Efanow, Apr 4, 2016.
  1. Michael Efanow
    Apr 4, 2016
    14
    Transistor substitution
    Hi guys, I'll try to keep it brief and clear, I'm after a M0265516 in TO220 package. Or a suitable substitute. It's from the variable speed on my Bosch cordless drill that's about 12 years of age, the variable speed unexpectedly stopped working for no obvious reason. How you can help. Thanks Michael
  2. hp1729
    Nov 23, 2015
    2,099
    233
    Best I can tell it is an SCR.I can find them listed for sale for about $1.65 but "no longer in stock". Try most any SCR in a TO-220 case. What do you have to lose? It already doesn't work.
  3. SLK001
    Nov 29, 2011
    852
    243
    I seriously doubt that it is an SCR for a DC variable speed controller. Probably, it is a house marked power transistor. Good pictures of the top and bottom of the speed controller will help in finding a substitute device.
  4. hp1729
    Nov 23, 2015
    2,099
    233
    Not bad reasoning. I find it listed under Thyristors but can't see it being a triac.
    So what damage can be done by plugging in an NPN, PNP or SCR?
  5. SLK001
    Nov 29, 2011
    852
    243
    I would want to see a schematic, or at least the requested photos. Perhaps it is part of a PWM output and the OP can see a pulse train going into the device.
  6. Michael Efanow
    Apr 4, 2016
    14
    I'll get the requested photos in a few hours guys. I've got a few scrs lying around from a touch lamp fix.
  7. Michael Efanow
    Apr 4, 2016
    14
    Here's some images. Today I've rang some local electronic component specialists. One tried to find the specs on the M0265516 but to no avail.
  8. Michael Efanow
    Apr 4, 2016
    14
  9. SLK001
    Nov 29, 2011
    852
    243
    Remove the device and test it to see if it is really bad. A lot of times, it is the printed potentiometer that is the problem. What is the number on the SOIC-8 part on the board?
  10. Dodgydave
    Jun 22, 2012
    5,155
    772
  11. Lestraveled
    May 19, 2014
    1,957
    1,218
  12. Michael Efanow
    Apr 4, 2016
    14
  13. Michael Efanow
    Apr 4, 2016
    14
    Any idea how I can get a data sheet on the m0265516?
  14. Michael Efanow
    Apr 4, 2016
    14
    Which part has that number on it, I can't see it?
  15. Michael Efanow
    Apr 4, 2016
    14
    How do I test it without a data sheet?
  16. Michael Efanow
    Apr 4, 2016
    14
    How can I test the printed pot?
    The drill used to only run at full speed with near %100 trigger, it used to run slow from say %5 trigger and increase with more trigger. What's happening now is its running at full speed with %5 trigger and through to %100 trigger.
  17. SLK001
    Nov 29, 2011
    852
    243
    Download the datasheet.
    Or here, use mine: HUF75339P3.pdf
  18. SLK001
    Nov 29, 2011
    852
    243
    If your drill is running at any speed, then there is nothing wrong with your transistor.
    Clean off the grease from the linear pot area and see if there are resistance variation from one end to the other. There is a lot of carbon in the grease that has sluffed off the pot - possibly too much to make the control salvageable.
  19. Lestraveled
    May 19, 2014
    1,957
    1,218
    Wrong. Look at the 3rd picture in post #7. There is a bypass switch for maximum torque when the trigger is pulled all the way in.
  20. Lestraveled
    May 19, 2014
    1,957
    1,218
    The Mosfet (huf75339) is $1.70 each at Digi-key. Also just as a test, almost any N chan Mosfet would work.
    My advise, spend a couple bucks and replace the Mosfet. If that doesn't fix it you can replace the trigger module (PN 2607200421, $46.24) or pitch the whole thing.
