Help finding 60Hz Notch Filter IC
Discussion in 'The Projects Forum' started by Ocelot, Jul 21, 2009.
  1. Ocelot
    Jul 2, 2009
    Hey everyone,
    I was wondering if anyone knew where I could buy a 50-60Hz notch filter IC. I've tried digikey and mouser and neither of them supply notch filters anymore. =\ whats up with that?
    Thanks.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    One op amp plus some capacitors and resistors gives you one - www.national.com/ms/LB/LB-5.pdf
    You can use just about any modern op amp in the circuit.
