help find total impedance with opamp
Discussion in 'Homework Help' started by dacrazyazn, Apr 28, 2009.
  1. dacrazyazn
    Mar 30, 2009
    22
    hey guys, i got a question, this may look simple, but i dont know where to start completely. I tried to simplify down the circuit but that doesnt really work just made it look more confusing..
    now im trying to work with the idea of Zin=Vin/Iin but the problem is i dont know what kind of opamp this is used for. it would be nice if i can get a hint.. just a small hint on how i could go about this. thanks!
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Denote the top node voltage as V1. Then denote descending node voltages below as V2, V3, V4 & V5. V5 is the node on Z5 above ground.
    Suppose the two op amps are ideal.
    Each op amp will drive the network to force the following conditions :-
    V5 = V3 = V1
    So the current in Z5, Iz5 = V5/Z5 = V1/Z5
    So V4 = V5 + Z4 x V1/Z5 = V1(1+Z4/Z5)
    So the current in Z3, Iz3 = (V3 - V4)/Z3 = (V1 - V4)/Z4
    and so on ...
    Eventually you'll find the current into node 1 {I1} entirely in terms of V1, and then you'll obtain Z1 = V1/I1
    Tricky question!
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    Correction on terminology at the end ....
    Not Z1 = V1/I1
    Rather Zin = V1/I1
  4. Skeebopstop
    Jan 9, 2009
    358
    Another thought process to come to the same answer as t n k is this:
    Assume ideal op-amps.
    That means the output impedance of the op-amp is 0.
    V1/I1 = Z1 = Zin = Vin/Iin.
    Yippeeee kayaaaa Motha $!%#!
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    Sorry another correction required ...
    The line
    should read
    So the current in Z3, Iz3 = (V3 - V4)/Z3 = (V1 - V4)/Z3
    Awfully difficult keep track of things I'm afraid!
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    Dacrazyazn,
    Just in case you think I'm stating the obvious - as perhaps Skeebopstop is suggesting - you should end up with an answer for Zin which is a relationship involving only the terms Z1, Z2, Z3, Z4 & Z5.
    :rolleyes:
  7. The Electrician
    Oct 9, 2007
    2,301
    338
  8. t_n_k
    Mar 6, 2009
    5,448
    783
    Hi Electrician,
    So there was something wrong with my method. Never analyzed this circuit before.
    Oh well - such is life.
    I have
    Zin = (Z1*Z3*Z5)/(Z2*Z4)
    What's the correct answer?
  9. The Electrician
    Oct 9, 2007
    2,301
    338
  10. dacrazyazn
    Mar 30, 2009
    22
    I worked it out and it was perfect! Thank you!
  11. t_n_k
    Mar 6, 2009
    5,448
    783
    Glad to hear you got it.
    Thanks Electrician - I was in serious self-doubt for a while.
  12. The Electrician
    Oct 9, 2007
    2,301
    338
    OK. Now for something completely different, derive an expression for the impedance at the top of the stack, if the opamp gains are not ∞, but are finite gains of A.
