Main board underside has nothing but solder holding in top side parts.Lets recap this.
Under the main board are no components, right?
On the bottom of the display is nothing but drivers, and uderneath it are just a few parts none of which is a battery.
The only remaining things are:
- the metal box on the far end of the unit, does it have some sort of connections? what is it for?
- the lid, somthing could maybe be under the keypad, but I doubt that
- the power supply, could that have some battery in it?
anyway, what is the battery used for?
It is an electronic timing device that records date and time when the racing pigeon arrives back from a race (pigeon wears a special ring).What is the exact purpose of this device?
The other option would be a coin cell battery, from 1/4" to 1" in diameter, and about 1/16" thick, to save settings in NVRAM or a Real time clock. Does it have a date/time that doesn't need to be set each power up? That type of battery can be hidden in many places, back of the LCD, under keypad, etc.
Does the device function even though it warns about the battery at power up?
Only the club master timer can set the member's timer, and that time is set in the club master timer by an automatic time signal from a national radio receiver.I does not look as if a battery would be under that PCB.
This has a feel of a "lifetime counter" if you can, try and set the date back a year, and see how the unit behaves then.
Would that battery you mention have solder points on the pcb underside to do a volt check to confirm battery is there?I have a feeling the battery is a lithium-polymer housed inside the metal box. It may not sound like a battery because the lithium cell is like an aluminum pocket of "stuff" and not hard like a traditional AA battery.
The metal box would make sense to prevent the battery from being punctured by the keypad.
That could also explain the high cost of replacing the battery because they would have to desolder the metal box to access the battery.
http://www.kdwebsolutions.com/test/diester_battery_can_solder.jpgPlease post a picture of the opposite side of the board from post #28.
That was excellent advice since all clocks are checked for seal breaks at the club before starting scanning the leg ring. However, I'm going to replace this clock with another make at £150 which starts me off with a new 5 year guarantee and with the big plus of their electronic leg rings being 40% cheaper than Deister.By the time you find the battery, remove the safety cage, remove the original battery, figure out the specifications of that battery (amp hour and discharge rate), find a company that supplies a suitable replacement battery and get it shipped to the UK (air freight is banned on bare lithium batteries), then you'll have to reconnect / solder the new battery into place and get the cage back into place. Finally, you'll have to convince the racing club that you didn't tinker with the clock and it will record / report accurately. I'd say, pay the £75 and get it done right. This hobby seems important to you and a dead battery half way through the season, or an accusation of a tainted device or other problem seems like it will disappoint you. I can see that £75 seems like a lot for a battery but, in the end, the assurance it was done right might be worth it.
by Aaron Carman
by Duane Benson
by Jake Hertz
