Help find battery location on curcuit board
Discussion in 'General Electronics Chat' started by morrell, Jan 21, 2013.
  1. morrell
    Jan 21, 2013
    14
    I have a 'Battery needs replacing' warning on my racing pigeon electronic timing clock and the maker says they will not sell me a battery, but would charge £57 plus postage to replace it.
    This particular model is no longer manufactured and is also out of guarantee. So I'm seeking help to firstly find out where the battery is located and what type it is. The image is here:-
    http://www.kdwebsolutions.com/test/diester_battery.jpg
    Regards,
    Dave
  2. kubeek
    Sep 20, 2005
    4,687
    805
    I am almost 100% sure that it is that cylindrical blue thing under the display.
  3. morrell
    Jan 21, 2013
    14
    Thanks kubeek. I have zoomed in on the blue cylinder in the image below and there is text on it, do you know what it would be called for me to try ordering from somewhere?
    http://www.kdwebsolutions.com/test/diester_battery_closer.jpg
    I also added the black circular thing to the image as it has a + sign on it in case that might be a battery.
  4. MrChips
    Oct 2, 2009
    12,624
    3,451
    I would say that black circular thing is the battery.
  5. morrell
    Jan 21, 2013
    14
    Thanks MrChips.
    I Googled BC 2200uf printed on the blue thing and it looks like its a capicitor (not that I understand anything).
    If the black circle thing is a battery, what would it be called for ordering?
  6. MrChips
    Oct 2, 2009
    12,624
    3,451
    With no part number visible, do three things:
    1) Measure the diameter of the black circular thing.
    2) Measure the spacing of the two solder connections on the bottom side of the board.
    3) Measure the voltage across the two solder connections.
  7. djsfantasi
    Apr 11, 2010
    2,900
    876
    The black circular thing looks like a piezo buzzer...
  8. theHOFIT
    Dec 16, 2009
    9
    There's no battery there that I can see. Maybe it's hidden under the display. Or in the top case somewhere?
  9. MrChips
    Oct 2, 2009
    12,624
    3,451
    +1
    I think you're right.
  10. kubeek
    Sep 20, 2005
    4,687
    805
    Yes that is a capacitor, and the black round thing looks like a piezo to me too. Try looking under the display or under the board.
  11. kubeek
    Sep 20, 2005
    4,687
    805
    What about that large metal thing in the back? I doubt that would be a battery, but who knows what that device actually does. Maybe they are just pulling your leg and there is no battery in there? :D
  12. Siksissk
    Jan 21, 2013
    It looks like the two black connectors would be a power in, with the diodes, fuse, and ptc in line with them.
    If your looking for a power battery, it maybe on the underside of that point of the PCB.
    If its a clock battery, you may find it on the other side of the PCB. (Probably housed in a metal cage)
    otherwise the silver lump next to the display, could be a very large lithium? (doubt it tho)
    The black cylinder is a buzzer, the blue cylinder is a cap.
  13. BillB3857
    Feb 28, 2009
    2,402
    348
    It would help to know if the unit is a stand-alone (no external power required) or one tht is usually connected to another power source such as a wal-wart (small power unit that plugs into the wall). If externally powered, I would start looking for a small disk type battery that,as others have suggested, would keep the clock running.
  14. morrell
    Jan 21, 2013
    14
    Thanks MrChips, disfantasi and theHOFIT.
    Googling Piezo Buzzer they do look like the black thing.
    My next door neighbor has a small thingy for checking volts and he gets no reading on the soldered black thing.
    The top casing has practically nothing in it as in the left image below and I can't see how the right image screen board lifts up to inspect below it. Unless those 4 corner black clips can be prized back, do you think that I should try prizing them back?
    http://www.kdwebsolutions.com/test/diester_battery_lid_screen.jpg
  15. kubeek
    Sep 20, 2005
    4,687
    805
    Yes moving the display away should give you no trouble. Have you checked the underside of the main board for any suspicious components?
  16. morrell
    Jan 21, 2013
    14
    Thanks siksissk and BillB3857.
    The timer does use external power.
  17. morrell
    Jan 21, 2013
    14
    Kubeek there is nothing at the back of the green board other than loads of solder points. I will have a go at prizing away the screen board.
  18. morrell
    Jan 21, 2013
    14
    The left image shows what is below the screen display and the right image the underside of the screen board.
    http://www.kdwebsolutions.com/test/diester_battery_below_screen.jpg
  19. kubeek
    Sep 20, 2005
    4,687
    805
    Lets recap this.
    Under the main board are no components, right?
    On the bottom of the display is nothing but drivers, and uderneath it are just a few parts none of which is a battery.
    The only remaining things are:
    - the metal box on the far end of the unit, does it have some sort of connections? what is it for?
    - the lid, somthing could maybe be under the keypad, but I doubt that
    - the power supply, could that have some battery in it?
    anyway, what is the battery used for?
  20. mcgyvr
    Oct 15, 2009
    4,787
    973
    I gotta remember that trick..
    Build in a warning after X amount of operational hours..
    "Battery needs to be replaced" please send $60 USD..
    and there is no battery ;)
    oh wait.. Maybe it is the first blue cylinder.. Its just a "supercapacitor" battery.
