help fan capacitor connection..
Discussion in 'General Electronics Chat' started by Dmtyper, Jun 1, 2015.
  1. Dmtyper
    Jun 1, 2015
    5
    Hello! I need help connecting capacitor to a fan. Recently a fan from kmart just decided to die..I am looking how to connect the new capacitor.
    The fan used to have a capacitor connection but the connection went of (long story short)
    I have now 3 wires red, black,brown If i pass current through the red and black the fan struggles and I have to push it for it to start. If I put the capacitor in series with the red and black will the capacito do its job?
  2. Bernard
    Aug 7, 2008
    4,240
    414
    Did you check continuity between brown & red, or brown & black? Just speculation- black- cap- brown. Need your findings.
  3. Dmtyper
    Jun 1, 2015
    5
    I will and let you know what I get
  4. Dmtyper
    Jun 1, 2015
    5
    The tester found continuity between black brown and red brown
  5. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,516
    A fan with cap generally has two identical windings, if the resistance measures the same, one common and two windings, then either can be used with a cap in series, if it runs the wrong way, swap cap to other winding.
    Max.
  6. Dmtyper
    Jun 1, 2015
    5
    cap?
  7. Dmtyper
    Jun 1, 2015
    5
    connect the capacitor in series with the red cable?
  8. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,516
    You can, but identify the common conductor for each of the two windings
    Max.
