Help - Dual Half bridge Isolation
Discussion in 'The Projects Forum' started by weetkee, May 23, 2009.
  1. weetkee
    Apr 30, 2009
    5
    I'm trying to build a T.E.N.S. Circuit that was featured in a Silicon Chip magazine issue a couple of years back. It uses an MC3406? DC-DC converter supplying IR2155 Half bridge driver to drive two IR 610 Mosfets for high side and low side. The circuit is for only one channel I wanted to add another. Can I just add another Half bridge driver and pair of mosfets? and will they be isolated from each other? or do I need to use a transformer, so that the channels don't have a common ground?
    I appreciate any help I can get. Thanks
  2. weetkee
    Apr 30, 2009
    5
    bump......
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Just a quick verbal explanation isn't quite enough information.
    Post the circuit.
  4. weetkee
    Apr 30, 2009
    5
    My apologies... here is the circuit.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    What is a T.E.N.S unit?
  6. weetkee
    Apr 30, 2009
    5
    T.E.N.S. Is short for trans-cutaneous electrical nerve stimulation. It helps to alleviate pain by over stimulation of pain receptors in the affected area so that they can't transmit a pain signal to the brain.
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    OK, thanks. I'll let folks a bit more familiar with MOSFETs answer this one.
