help drawing logic diagram
Discussion in 'Homework Help' started by gammaman, Jun 5, 2009.
  1. gammaman
    Feb 14, 2009
    29
    I have no idea how to approach this. It does not seem clear to me.
    Can someone clarify or give me a source to help me do this.
    The standard alphanumeric binary code is the ASCII(AmericanSttandard code for Information Interchange) which uses seven bits to code 128 characters. Binary information transmitted through network communication is subject to external noise. The detected errors cannot be corrected but their presence is indicated. The usual procedure is to use the parity bit. A parity bit is an extra bit included with ASCII code. The P(odd) bit is chosen to make the sum of all of 1’s odd. The P(even) bit is chosen to make the sum of all of 1’s even.
    During transfer of information from one location to another, the parity bit is handled as follows. At the sending end, the message (in ASCII code) is applied to a parity generator, where the most significant bit is the Parity bit. At receiving end, all the incoming bits are applied to a parity checker that checks the proper parity adopted (odd or even). If there are no errors, the parity bit will be removed from message. Otherwise the message will not be acknowledged as received and the message will have to be retransmitted.
    Parity generator and checker networks are logic circuits. Your job is to construct both circuits for sending and receiving sides in the same location. The location can control line for sending or receiving ASCII code.
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    This sounds like a classwork assignment. If so, then I will move it to the HOMEWORK forum.
    hgmjr
  3. gammaman
    Feb 14, 2009
    29
    Yes please do.
  4. Mike Mandaville
    May 27, 2009
    81
    Do you know what a logic diagram is?
  5. gammaman
    Feb 14, 2009
    29
    Yes a logic diagram is a representation made up of gates.
  6. gammaman
    Feb 14, 2009
    29
  7. Mike Mandaville
    May 27, 2009
    81
    It looks like you've got it. I really need to get myself another copy of Don Lancaster's "CMOS Cookbook", because I know that this subject is covered in one of Don's books, and I think that's the one.
  8. gammaman
    Feb 14, 2009
    29
    Thanks, you are a real help:)
