Help - Draw the logic diagram for the following Boolean expressions.
Discussion in 'Homework Help' started by ajnsmt, Nov 17, 2010.
  1. ajnsmt
    Nov 17, 2010
    Question
    Draw the logic diagram for the following Boolean expressions. The
    diagram should correspond exactly to the equation. Assume that the
    complements of the inputs are not available.
    a. XYZ' + XY' + X'Z
    b. (A' + BC + CD') (B' + E'F')
    thanks
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    What part are you having problem with? This is pretty basic, and it is against policy for us to do your homework for you. ABC is a 3 input AND gate, ABC and DEF are 6 inputs, qty 2 3 input AND gates and a 2 input OR gate. Generally the convention is to put an inverting signal where the input is inverted, but it can as easily be an inverter.
  3. ajnsmt
    Nov 17, 2010
    sory but . This answer was not enough to me
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    Like I said, we do not do your homework for you. So instead of focusing on that, think about why you don't know how to do this. What part of the problem do you not understand?
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    This has all your conditions. You should be able to figure it out from there.
    I'm throwing in my drawing templates (use with a graphics program such as MS Paint) that is part of my PaintCAD program.
  6. ajnsmt
    Nov 17, 2010
    I made myself look at you right? I drew a bad :) thanx
  7. thatoneguy
    Feb 19, 2009
    6,357
    718
    Logisim
    That is a handy program for verifying your designs.
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    Your first sheet is correct. Nothing wrong with pencil and paper, but they sell templates to make your drawings neater. I use the electronic version myself, but I'm also pretty handy free hand drawing it too.
