I want to start building a distance sensor project. Basically, the sensor has two parts. Whenever the two parts are separated by a certain distance, then one of the parts will light up.
The first part will need to emit certain signal all the time. While the second part will need to receive the signal and light up when there is no signal. I hope that the first part will not use too much energy and preferably can operate with solar energy.
Any idea how should I start this project?
