Hello All!
This is my first post here, so thank you in advance for any answers and I'm happy to be part of the community.
I work for an electronics restoration company. We clean, repair, test and restore electronics after smoke, fire or water.
I am the primary IT electronics tech. So when it comes to circuitry I am a bit above a novice but not much. I can identify components and solder easy things but I am in no way advanced or even a strong intermediate.
The issue
A client had an incident involving water. The item were being stored and were not powered on or connected to power at the time of the loss. At most these items had some dampening from the water and were no where near soaked. We see this all of the time. Items are cleaned with deionized water and solvents and placed in a static free dry room then they are tested or in this case items were cleaned using denatured alcohol and contact cleaner and dried. All common practice that yields 90% positive results.
After cleaning and drying the items are tested. The items in question are a Flashforge Dreamer 3D printer and a Cisco SG500X-48 Managed Switch. We cleaned and dried them and they tested fine. The switch was tested to power on and handle a little bit of network traffic. The 3D printer was tested with a 4hr print and a 14hr print both prints went well and the unit was on for about 48hrs.
Both the 3D printer and Switch were returned to the customer. A few days later he complained about the items not functioning properly when he tested them. The client is extremely tech savvy. I guarantee he knows more about circuitry than I do. His complaints were that one of the extruders on the 3D printer wasn't functioning properly and that the switch had a loud fan.
We picked up the items and brought them back to test. Upon return of the items the switch was plugged into power and the tech went to the bathroom. Literally 2min later one of the network jack arrays started smoking the board. It is a perfect circle under the first nic connection array. The 3D printer I had up printing via sd card. It was functioning well. Later I plugged in the usb to test other settings via the pc software and 2 min later more magic smoke and an IC behind the usb port fried and caused the unit to fail.
Now these issues are consistent with what water could be expected to do to a circuit. However they did this after we followed a very much practiced restoration process and after we tested them and the client tested them. This seems very fishy to me. It is highly uncommon as we do this all of the time. So my question is what could be done to these circuits or components to cause this? As in is there a way to tamper with the devices to yield the issues observed. The switch went first so I visually inspected the 3D printer prior to working on it. Please see attached photos. I saw nothing odd about the components of circuits involved upon visual inspection, I did not break out a meter prior.
I have attached pictures with the affected boards and components highlighted.
3d printer prior
3d printer prior
3d printer after
Switch prior
Switch prior
Switch prior
Switch after
Switch after
The issue
3d printer prior
3d printer prior
3d printer after
Switch prior
Switch prior
Switch prior
Switch after
Switch after
