Help designing the circuit
Discussion in 'Homework Help' started by nenadilic84, Jul 22, 2010.
  1. nenadilic84
    Thread Starter Active Member
    Aug 7, 2009
    62
    can someone give me a direction in designing the circuit that is suppose have an operation drawn in the diagram.
    [​IMG][​IMG]
    [​IMG] It has one input and 4 outputs. When the input signal go high nothing happens at outputs, but when it goes low the first output is triggered and it stays high for the same period of time as the input signal was. Next on low of the output 1 the output 2 is triggered and so on. Thanks for your suggestions.
    Regards,
    Nenad
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    This looks so much like an assignment that I am going to move it.
    Hint:Use the input as a clock - look up Johnson counter.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    I'm thinking four monostables, each triggered by the preceding unit.
  4. nenadilic84
    Aug 7, 2009
    62
  5. nenadilic84
    Aug 7, 2009
    62
  6. Georacer
    Nov 25, 2009
    5,151
    1,266
    If input is arbitrary and user defined, then how the circuit will know in advance the t_{on} in order to calculate the t_{on}/4. Doesn't seem very feasible to me...
  7. ozjon69
    Member
    Jul 19, 2010
    10
    Well, a microprocessor is probably the only simple way to do it. (first cct)
    Somehow, the circuit has to remember the value Ton.
    I can't figure how to do that with discretes
    The second circuit is impossible!
  8. nenadilic84
    Aug 7, 2009
    62
    Can you please give any suggestion for the second design of the circuit.
    I think that some frequency divider will do, but how to trigger on the falling edge?
    Thank you
  9. Georacer
    Nov 25, 2009
    5,151
    1,266
    What were the problems with your design with the Flip Flops? What results didn't satisfy you?
    Concerning the second circuit, understand that you ask of a circuit to calculate the one quarter of a time interval that isn't yet known. How do you expect that to happen? Or did you describe your problem poorly and what you really wanted is to give the input time interval first, let it finish, and then start the chain of pulses?
  10. retched
    Dec 5, 2009
    5,201
    313
    If you waited 1 cycle to get t_{on}, then used that to trigger the 1/4t pulses for each additional cycle, that would work.
    But, you will need a way to get t_{on}
    Is t_{on} a pre-defined time?
  11. nenadilic84
    Aug 7, 2009
    62
    Yes you are right. But I expect that the simple way is to use a microcontroller with analog input that is going to define a t_{on} and make the pins high in the desired order. Thank you for the help.
    i will post the solution here.
  12. retched
    Dec 5, 2009
    5,201
    313
    That is correct
    You could use an analog or digital input to get the frequency of the pulse, then divide by 4.
    Trigger the output of T/4 with the input rising edge of the next cycle.
  13. big5824
    Jul 15, 2010
    9
    Looks just like a serial to parallel shift register to me, although youd need a clock signal that isnt displayed
