Help Designing Circuit from Transfer Function
Discussion in 'Homework Help' started by aje35, Aug 1, 2012.
  1. aje35
    Aug 1, 2012
    I am an electrical engineering student and taking an advanced circuits class.
    I have been tasked to design a circuit from a given H(s) transfer function. The guidelines I must operate within are using:
    - an op-amp
    - resistors ranging from 100Ω to 10MΩ
    - capacitors ranging from 200pF to 10μF.
    The given transfer functions are:
    H1(s) = (0.1s + 6000)/(s + 1200)
    H2(s) = 60000/(s+500)^2
    Any insight or help in to this problem would be greatly appreciated.
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    I found this post in "the completed projects forum", where it will stay "moderated" (invisible to others).
    As it says it is for completed projects and not for questions.
    I moved it over here and made it visible, so others can reply on the post.
    As it looks like homework, what have you done to get a solution?
    Bertus
  3. #12
    Nov 30, 2010
    16,657
    7,303
    I only looked because I'm completely useless at this and hoped to learn from somebody else's answer.
  4. Bill B
    Nov 29, 2009
    61
    Is this for the design of an active filter?
  5. #12
    Nov 30, 2010
    16,657
    7,303
    The "S" terms would seem to indicate that. Hoping aje35 responds.
  6. mlog
    Member
    Feb 11, 2012
    276
    36
    The first one looks like a lag filter, or more appropriately a lag-lead, which means the lag is dominant. The second one looks like a critically damped 2nd order low pass filter.
  7. daviddeakin
    Aug 6, 2009
    207
    27
    Find the DC gain of the transfer function (when s\rightarrow0)
    In this case that gives 6000/1200 = 5
    You also have a pole at s = 1200 rad/sec
    And a zero at 6000/0.1 = 60000 rad/sec
    This is a low-pass shelving filter, so you could perhaps use the opamp to provide a gain of 5, and then follow it with this:
    Here you have a DC gain of 0.24
    And two poles at 500 rad/sec
    You could perhaps use a filter like this:
    which takes care of the DC gain and one pole, then follow it with a passive RC filter to give the second pole.
