I'll assume you have or will work out the mechanics of trigging the switches. I'll assume a worst case scenario where the servo stops on one of the switches keeping it triggered. In that case, we'll want to use an edge-trigger so the LED and sound don't continue to go off repeatedly.Yes I plan on having an arm attached under the deck gun, as a servo turns the gun it`s arm pushes a switch mounted in several spots of travel.
Will the switches be normally open (N.O.) or normally closed (N.C.) or both?
I'll review the capabilities of the sound module again. I believe it has information on how it will operate under a number of conditions with options, so we may not need any additional circuitry.As that switch is pressed and released, I want a momentary flash of the Red LED as well as the sound from the audio circuit to activate, both are not wanted to be on for long time, think of a cannon firing, bang/flash, don`t know the second length but I think you might have the idea of what I`m after. All this using maybe 555 circuits OR other?
Can you locate the sound you're interested in playing and see how long it is? Maybe post a link to the sound file?
Also picture how long you want the LED on with respect to the sound length. For example, say the sound is a "BOOM" that lasts half a second. Then the LED will be on as long as the sound. However, another scenario is maybe a BOOM with a whistle (indicating a missile is traveling through the air). In this scenario, the sound is on for a couple of seconds or more, but you'd only want the LED lit for say half a second.
