help!! d flip flops
ernestpandada
Joined Jan 5, 2015
hi!
i need to make a counter that counts from 00~59. then it will go back to 00 and start counting again. on top of that, there's a start/stop and reset button. when the start/stop button is pressed it will start or stop. however, if the restart button is pressed it will go to 00 and start counting! i cant seem to think of any ideas.
im only given:
x1 LS7474
x1 LS7432
x1 LS 7400
x2 LS 7493
x1 LS 74112
not all the ics have to be used.
PLEASE HELP ME ASAP!!!!
WBahn
Joined Mar 31, 2012
30,062
Break the problem down into smaller problems. You might start with a counter that counts from 0 to 5 and then starts back at 0 again. Get that designed and tested. Then add in the ability to pause it using a single start/stop push button. Then add in the ability to force it back to zero. Then extend it from 0-5 to 00-59. Or do these things in a different order as makes sense to you.
But in any event YOU need to show YOUR best attempt to solve YOUR homework.
