[HELP] D Flip Flop understanding
Discussion in 'Electronics Resources' started by Aresden, Jan 5, 2012.
  1. Aresden
    Nov 11, 2011
    Hi guys I have abit of problem understanding the DFF when connected like this.
    Assuming clock is activated and Q is initially 0, why would it stay at 0?
    Why would it go to logic 1 and hold at logic 1 when the pulse switch (PB_DPST) is pressed?
    Help greatly appreciated, many thanks
    Uploaded with ImageShack.us
  2. MrChips
    Oct 2, 2009
    12,641
    3,456
    Firstly, make sure -PR and -CLR are both connected to logic HIGH.
    I am not sure that I understand your questions.
    A flip-flop is a sequential circuit (as opposed to a combinational circuit) where the element of time and the sequence of events come into play.
    You need to know and understand the truth-table of a D flip-flop (specifically a 7474 type. Not all flip-flops are the same).
    Q = D after the LOW-to-HIGH transition of CLK.
    What else can it do? Since there are no transitions, Q will remain at 0.
    No. Q will assume the state of D on the LOW-to-HIGH transition of CLK.
    Hence you should observe a change only after the push-button is pressed and released.
    In this case, since D is connected to -Q, the flip-flop will toggle between 0 and 1. (You have created a T flip-flop).
    (This is a simulation. With a real circuit you will observe random behaviour because of a phenomenon called switch bounce.)
  3. Aresden
    Nov 11, 2011
    thx for the help mrchips, however I still have questions in red
  4. MrChips
    Oct 2, 2009
    12,641
    3,456
    At start up, Q can be either state, 0 or 1.
    If D = 0 -> Q = 0 after LOW-to-HIGH CLK. Hence -Q = 1
    Now,
    D = 1 -> Q = 1 after LOW-to-HIGH CLK. Hence -Q = 0
    Hence Q will change state, 0..1..0..1..0..1... on every LOW-to-HIGH transition of CLK.
