Help converting schematic to breadboard - vibration sensor to led and buz.
Discussion in 'General Electronics Chat' started by Jeff Simons, Jan 23, 2016.
  1. Jeff Simons
    Jan 23, 2016
    17
    Hi there,
    I'm pretty new to electronics and am having a bit of trouble trying convert the attached schematic diagram onto a breadboard to test. The main issue I'm having is understanding linking up the IC, is there a way of simplifying the circuit diagram?
  2. GopherT
    Nov 23, 2012
    6,300
    4,020
    So, the CD40106 is a hex inverted (it has six inverters). The schematic shows the six inverters as U1a , U1b, and so on until U1f.
    It doesnt matter which of the six are used for a, b, c etc. puts make sure that the Input for a aligned with the output for a on the chip. The schematic (pinout) of the chip is on the datasheet. Just google cd40106 datasheet.
    Two pins are not shown on your schematic but you will see it on the CD40106 datasheet. The power (+ and 0).
    When I assemble a circuit from a schematic, I place a wire for each line on the datasheet and then mark it on the schematic that I placed the wire. Make sure everything gets marked. Your breadboard will not look (physically) like the schematic when done. As long as the wires all go to the right nodes, all should work. If you are still not sure, google bread boarding a circuit and click on videos, there are many tutorials to show you how it is done.
    ISB123 likes this.
  3. shteii01
    Feb 19, 2010
    3,500
    511
    I only see one IC, the CD40106B. The circuit diagram is the simplified view. The actual physical connections will be more complicated than what you see in circuit diagram.
  4. absf
    Dec 29, 2010
    1,493
    374
    I have put in the pin no for you. Does it make any easier for you?
    Allen
    Sinus23, Alec_t, dl324 and 1 other person like this.
  5. Jeff Simons
    Jan 23, 2016
    17
    Thats a lot easier, also the explanation from GopherT has made it clearer for me, thanks very much
    absf and GopherT like this.
  6. Alec_t
    Sep 17, 2013
    5,961
    1,133
    Note, the 300 Ohm resistor represents the buzzer for simulation purposes only: it is not something you actually include on the breadboard. Likewise the 100 Ohm resistor shown as the sensor.
    C2 should be as close to the IC pins 7 and 14 as is practical.
  7. Dodgydave
    Jun 22, 2012
    5,138
    767
    Seems a waste of gates putting four in parallel, just use one, its a schmidt trigger.
  8. GopherT
    Nov 23, 2012
    6,300
    4,020
    It's hard to leave half those gates in the storage bin and, I thinks the designer was abiding by the rule, never leave inputs floating.
    I agree with you, though. One is enough and this configuration does put big stress on those outputs if they all do not switch at exactly the same time (essentially sourcing or sinking the full load of the partner inverters for very short bursts).
    Dodgydave likes this.
  9. Jeff Simons
    Jan 23, 2016
    17
    You'll have to excuse my ignorance, this is the first time i've tried this since school...
    I'm still having some issues, basically I tried to put it all together today and it just blew the LED without the sensor being activated so I've started from scratch , is the IC linked up correctly in this image?
  10. ISB123
    May 21, 2014
    1,240
    531
    Are you sure the LED was oriented properly and where is the resistor?
    Dr.killjoy likes this.
  11. Jeff Simons
    Jan 23, 2016
    17
    Just changed the position of the resistor and now the LED is just staying on.
  12. absf
    Dec 29, 2010
    1,493
    374
    One of the components on pin 10 of 40106 is shorted.
    Allen
    Sinus23 likes this.
  13. absf
    Dec 29, 2010
    1,493
    374
    I have made the breadboard as below... Does it help you anyway?:D
    Don't have 9V battery in my library and I don't know how to bend the R1 resistor 360° so it occupies 2 adjacent holes, so I use 2 resistor with half the value 220K+220K~=470K. C3 10uF (above the LED) is added by me for extra decoupling.
    Allen
  14. tracecom
    Apr 16, 2010
    3,878
    1,396
    Wouldn't it be better to put C2 closer to the power pins of the IC?
    absf likes this.
  15. Jeff Simons
    Jan 23, 2016
    17
    Thats very helpful of you, thanks very much! Is that 2 x 1uF capacitors? Ive just managed to blow the last LED i had fiddling around with it! Will the circuit still work I just bypass the led and resistor for test purposes until i get chance to pick up some more?
  16. absf
    Dec 29, 2010
    1,493
    374
    Yes of course, I was doing it in a hurry. Hope the OP take note on this...;)
    Allen
  17. Jeff Simons
    Jan 23, 2016
    17
    Ok I did it by that breadboard, minus the LED and I'm getting a crackling from the speaker for a second or so when the battery is first connected, then nothing when the sensor is tapped. Is the schematic correct? sensor.jpg
  18. absf
    Dec 29, 2010
    1,493
    374
    A speaker is not a buzzer.
    If you dont have a buzzer, just put back the LED and resistor..
    Allen
  19. absf
    Dec 29, 2010
    1,493
    374
  20. Jeff Simons
    Jan 23, 2016
    17
    Sorry, it is a buzzer not a speaker. I removed it anyway, just hooked up the LED but its the same, just staying on permanently. Whether the sensor is connected to the breadboard or not is having no effect on the LED. Is there a different circuit I could use that would serve the same purpose?
