I found an inverter circuit for a 4W fluorescent light tube. But, it is from Europe and its output is 230V. Living in the US, I would like a 120V output. I know that the transformer needs to be different. What else do I need to change? The power MOSFET and the 100n,1200V cap? Do all the component values need to be re-calculated? The schematic shows 2 options on the output: with 2 transformers and 1 transformer. I want to build the circuit using 1 transformer which they say should work for a 4W fluorescent tube.
