Help confirming if this circuit will actually work
Discussion in 'Homework Help' started by mackingu, Nov 15, 2007.
  1. mackingu
    Nov 15, 2007
    Howdy,
    I'm trying to control a small little radioshack motor with a DPDT switch to make it go forward/stop/reverse. I'll be using it to open/close a door (attched to a gear/reducer+arm similar to the way your car windows go up/down) on a tupperware container. I was just wondering if the schematic i drew up will work. I'm kind of new to drawing diagrams, so please forgive me if i didn't use the correct symbols and such.
    I'm probably going to use a 3VDC motor from radioshack. Oh, and I didn't add any resistor(s) because I forgot. Oops. "Will this circuit work?" is the main thing I would like to know
    Also, if anyone could provide suggestions (or links on the ACC main site) on how to automatically stop the motor from running (since the distanance the door will close is only an inch or so) it would be greatly appreciated.
    Thanks!
  2. cheddy
    Oct 19, 2007
    87
  3. mackingu
    Nov 15, 2007
    Thanks!
    Seems like I did screw it up afterall.
    any suggestions on automatically stopping the motor? i'm still on volume 3 of the ACC guide and have yet to find anything to help.
  4. cheddy
    Oct 19, 2007
    87
    Oh well if you were going to automatically stop the motor you might want a different way to set up the DPDT switch. You are going to need to attach 2 leads to both the motor terminals. that way when the motor reaches the top you can "trip" the wire and open the circuit.
    This should give you some ideas
  5. Ron H
    Apr 14, 2005
    7,050
    657
    You didn't screw it up. You can do it either way.
  6. mackingu
    Nov 15, 2007
    Thanks for the help, gents. Really 'preciate it!
