Help configuring radio controlled h bridge solenoid circuit
Discussion in 'The Projects Forum' started by jgeidel1022, Oct 29, 2015.
  1. jgeidel1022
    Oct 29, 2015
    I am working on a project to control a latching solenoid via radio control. The solenoid is a dual position solenoid using a magnet to latch in the retracted position. The solenoid will not work properly unless current is limited to between 0.75 and 1 amp. It's resistance is 3.3 ohms so it naturally wants to draw upwards of 4 amps from a 12 volt source. My knowledge of electrical components is not very deep but I took some courses in college and have a general knowledge of basic circuits.
    I am planning to use a 2 channel RF receiver in combination with an L293 quadruple Half H-Drive to control the solenoid.
    I am concerned with limiting the current to a value between 0.75 and 1 amp and do not know an effective (or generally acceptable) method of doing so.
    My thought was placing the whole circuit as a load on a transistor which I will size a base resistor accordingly to supply only 1 amp through the emitter. I am in a little over my head at this point and any pointers would be greatly appreciated.
    I have attached a drawing for reference.
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    How long does the solenoid have to remain powered after its initial pulse?
  3. jgeidel1022
    Oct 29, 2015
    Momentarily. <1 second probably more in the 0.25s to 0.5s range.
    Edit: The duty cycle will be very low. Activated once every 30 minutes or so
  4. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    A typical RC Li-Po battery supplies many amps for motor and servo's that load would be trivial for even a small size.
    Max.
