i want to design a simple robot without using micro-controller that detects clap....and on hearing the clap it changes its direction
the basic working of this project would be:
1)a clap switch circuit that uses microphone to detect clap and then provide an appropriate output voltage
2)that output voltage can be used to drive an H-Bridge which then changes the direction of rotation of a motor ( i use two motors one for forward motion and one motor which will be used to turn against the motion of previous motor so as to change direction of the robot......)
please help me with the logic so that i am able to design the project.....
Actually i dont have much knowledge about H-bridge so while describing anything please provide the circuit diagram of the h -bridge(or the h-bridge IC) and also the clap switch.........
