Help! Circuit output not right
Discussion in 'General Electronics Chat' started by peaac, Sep 25, 2011.
  1. peaac
    Sep 17, 2011
    11
    So I have this chip... SN74LS47N which I found the datasheet for and it is a TI BCD to 7-Segment driver.
    I have two of these and I have checked the circuit about 10 times and this is what I am getting:
    I have VCC = 5v
    and connected the H to the same VCC for high and to ground for L.
    What I see is that the chip "almost" works but the H and L outputs are at 0.11v and 0.07v!!! And I cannot figure out why!
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Here is a link to the datasheet:
    http://www.ti.com/lit/ds/symlink/sn7447a.pdf
    Note that the very first thing on page 1 of the datasheet after the part numbers, description and revision date, is a bullet that says:
    "Open-Collector Outputs Drive Indicators Directly"
    Open collector means that the outputs can sink current, but cannot source current.
    If you wish to see if they are working as expected, use a ~270 Ohm resistor from +5v to the output; the resistor will source current so that you will then see the voltage on the output pin change.
  3. peaac
    Sep 17, 2011
    11
    Thanks! That was an aha moment!
