Help Choosing MOSFET
Discussion in 'The Projects Forum' started by Chris15, Jun 4, 2010.
  1. Chris15
    Thread Starter Active Member
    Apr 15, 2009
    252
    Hello Again
    I have a small circuit that is made to switch 5, 5mm LED's on and off randomly, i want to add more LED's and larger ones so i though about a relay but they aren't fast enough. i cant really measure the voltage as when i connect the multimeter it changes too fast to get an average. i need a MOSFET that will turn on easily with the 5mm LED voltage
    Thanks, Chris
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    If you can't measure the voltage at the LED, what is the voltage at the supply? Some mosfets are made that turn on with as little as 2.5V (e.g., STS5PF20V, which is P channel)? Can you provide your schematic?
    John
  3. John P
    Oct 14, 2008
    1,638
    225
    Or, use a bipolar transistor and a base resistor that give you a reasonable base current (say 1/20 of the desired LED current). That could be operated off any voltage down to less than 1.
  4. Chris15
    Apr 15, 2009
    252
    The supply is 9V
    When i measured it i saw it jump from 1.5v up to 8v, the circuit is a TIP31C Transistor with an audio (P2) connecter, you plug it into an audio output and it beats the the music.
    So that is all of the specs i can give now i just need the MOSFET
  5. Chris15
    Apr 15, 2009
    252
    This is the schematic i put an arrow where i want the mosfet to be so i can connect about 30, 10mm white/Blue LED's
    Chris
  6. Chris15
    Apr 15, 2009
    252
    Any one know any answers?
  7. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    Take a look at Bill's thread on:
    LEDs, 555s, Flashers, and Light Chasers
    http://forum.allaboutcircuits.com/showthread.php?t=19075
    Bertus
