help choosing microcontrollers
Discussion in 'Embedded Systems and Microcontrollers' started by angelita, May 29, 2010.
  1. angelita
    May 29, 2009
    this is the first time im dealing with microcontrollers
    i just want to know if my choice is good
    i have A PROJECT to process human sound automatically
    the controlling must be using USB interface
    the processing to noise and echo cancelation
    then transimt the sound bACK without saving it
    i must do that with uControllers not DSPs
    i choose PIC18 and dsPIC30F
    i choose pic18 bcoz im intersted in the USB interface
    and i chhose dsPIC30F bcoz this support noise andecho cancelation library
    is it good or not ???
  2. maxpower097
    Feb 20, 2009
    Ok the dsPIC30 is a dsP. So I would look at the PIC18 - PIC32. Each one will be more powerful. Surely a dsPIC would be better for this but if you can't use a DSP then your gonna be looking at the others. I would suggest a PIC24 because it has most of the power and features of the PIC32 but cheaper. But you may want to ask your teacher or boss if you can use a dspic. They may just mean you can't use a true blue full fleged dsp.
