Help choosing a multimeter
Discussion in 'General Electronics Chat' started by ehayashi300, Jan 23, 2013.
  1. ehayashi300
    Jan 23, 2013
    Hello Everyone
    I’m new here and looking for some advice choosing a new multimeter that will last me a few years. I like Fluke’s range and have this one in mind
    http://www.newark.com/fluke/fluke-117/multimeter-digital-handheld/dp/83K1721
    I think it does everything I need, but just wanted to check there’s no point looking further up the range? I’m primarily going to be using it for tinkering with Arduino kits, audio amps etc.
    I was originally trying to stick to a $200 budget… Is there any point shelling out more for a high precision device just in case I need one down line?
    Fancier alternatives include:
    Fluke 177
    Fluke 87-5
    Edward:)
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    You will be happy with the Fluke 117 that is similar to my Fluke 79III that I bought about 18 years ago and it still works perfectly.
  3. PackratKing
    Jul 13, 2008
    850
    216
    Bought a Fluke 77 in 1984, for measure of tiny currents in cybernetic automation of 35mm Cameras.
    It has performed flawlessly since, only being out to Fluke for repair and recertification once out of warranty, because I was a dunderhead and checked current on an Ohm scale and retarded it slightly... :rolleyes: They repaired it No charge.
    Have a couple of those " Harbor Fright :D " cheapos for field and automotive troubleshooting.
  4. GopherT
    Nov 23, 2012
    6,300
    4,020
    The new generation from Fluke has a safety feature reminder that beeps when you turn on AMP feature but still have the anode lead plugged into the VOLT/OHM socket.
    PackratKing likes this.
  5. spinnaker
    Oct 29, 2009
    5,063
    1,160
    Apparently there are a lot of "dunderheads" out there an Fluke got tired for repairing their burned out meters. :)
  6. GopherT
    Nov 23, 2012
    6,300
    4,020
    It doesn't take a "dunderhead", it can just be someone focused more on creating something new or solving a problem more than they are focused on setting up their instrument. It is also more than an equipment issue, it is a safety issue when working at the upper voltage limits of the equipment.
    I've said it many times and I will say it again, "Show me someone who has never made a mistake, and I will show you someone who doesn't get much done".
    I will pay for auto-power off and "fail-safe" devices any day to keep productivity high and to keep people and equipment safe.
  7. thatoneguy
    Feb 19, 2009
    6,357
    718
    All of the Fluke 87 (original, III, and V) have that feature.
  8. PackratKing
    Jul 13, 2008
    850
    216
    I cheated a wee bit with my Fluke 77... I got tired of switching the leads around for different functions, so wired them all through a 4 wafer/pole 4 position rotary switch.. didn't seem to louse up the accuracy at all...
    I considered a larger number of poles, so I could double up for the the ammeters for slightly beefier contacts, but I severely limit myself to small voltages / currents with the Fluke, and use the 'harbor-fright' or radioshack units to beat on... :D
