Help... CD-Robot
Discussion in 'The Projects Forum' started by shank09, Jan 8, 2012.
  1. shank09
    Jan 8, 2012
    12
    Hey guys!
    I am new to this site...
    I am a high school student, my class is making this robot...
    my teacher told us to research about this, but we found nothing...
    Then I found this site... Can anyone tell me what i have to use to accomplish this robot... i need help in
    - how to time this robot to open and close the door...
    - What chip should i use and how should connect it... (i dont know srry)
    - making a circuit diagram...
    http://www.youtube.com/watch?v=PSpMFrp2zxk
    PLZ skip to 1:00... we have to do that...help me out plz
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    What contraints has your instructor placed on the materials you can use? What parts are you familiar with already?
    hgmjr
  3. shank09
    Jan 8, 2012
    12
    Hey, hgmjr
    My instructon/teacher told us to find out how to do it...
    it should work how it looks in the video, it should be able to cross the rope...
    btw, he told us we might use Flip-flops or something... My teacher was very vague about this project.
    i want to get a heads up on this robot...
    thanks
    Shank
  4. shank09
    Jan 8, 2012
    12
    PLZ someone help me out
  5. hgmjr
    Jan 28, 2005
    9,030
    214
    So you are free to use your own design then as long as it accomplishes the end goal of traversing a wire under its own power.
    hgmjr
  6. shank09
    Jan 8, 2012
    12
    Yes :D I can use any design
  7. hgmjr
    Jan 28, 2005
    9,030
    214
    Are you working with a team or are you working on your own?
    hgmjr
  8. shank09
    Jan 8, 2012
    12
    i am working with my friend... (partners)
  9. hgmjr
    Jan 28, 2005
    9,030
    214
    What ideas have you and your partner come up with so far?
    hgmjr
  10. shank09
    Jan 8, 2012
    12
    umm, we were thinking to use some sort of a timer, to make the door open first and then the lock to go up and hold...
    the problem is how and what should we do to get the door to close, and then lock should go down... and do it all over again...
    Useful info:
    - There are 2 motors
    - one for opening the door
    - the other one was for the lazer to move up and down
    - If I connect the motor the right way to the battery it opens the door, if i switch positive + and negative - the door closes.
    ps. the motor is reversable
    (this applies to the lazer motor too)
  11. thatoneguy
    Feb 19, 2009
    6,357
    718
    Why not put some sort of brake on the rear wheel when the front is extending? Like a gripper clamp or similar?
  12. Andrewcusick
    Sep 24, 2007
    5
    HI Shank,
    Looking at the original project this utilises a BASIC stamp microcontroller - this is easy enough (if you have one ) to control electrical signals to the existing macinery of your CD drive - standard current of 9V is quite easliy provided as it's intended to drive RC servos - I'm a real beginner at this, but produced the following in a weekend
    http://www.youtube.com/watch?v=QCDgPt7PMfA
  13. shank09
    Jan 8, 2012
    12
    We are using a 555timer connected with a 393 counter to generate the signal to drive MC14555 CMOS Demultiplexer which would drive the motors for 2 second intervals. However we have been experiencing problems with the CEMOS demultiplexer and it does not do work as we expect it to. Your help will be appreciated. Thanks
  14. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    You will definitely need some sort of "brake" on the front end (the door) to hold it there while the back end catches up. A simple on-off timer (done with the 555) should be enough to open and close the door. A transistor could replace the mechanical switch to open and close it, and the transistor could be controlled by the 555 output. The "brake" is really the important part, and can be done several ways. You can probably just wire up a motor to act as a clamp, or even have a simple mechanical ratchet of some kind.
    It's important for you to know that we're not going to give you all the answers. We won't tell you exactly how to do it. It is your project, so you will need to do most of the thinking. Please understand that, and we'll go from there :)
    Good luck!
    Regards,
    Der Strom
    shank09 likes this.
  15. shank09
    Jan 8, 2012
    12
    for break and all that we are using h bridge...
    that is all sorted out...but the thing is that the CMOS demultiplexer isnt wrking...
    it doesnt generate the output we want it to...
    Please help out a little more (about 15 students stuck, so please help)
  16. thatoneguy
    Feb 19, 2009
    6,357
    718
    Please post a schematic of your current circuit, and go into much more detail about the CMOS demultiplexer issue. Include part numbers, resistance values, etc.
  17. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    You're starting to sound like you think we're required to help you. As I mentioned before, we are not here to give you the answers. We can help with individual issues you might have. Your question is way too broad though. How are we supposed to know what's wrong with the demultiplexer? You have not provided us with a schematic or a picture of your setup. You have not told us what it is doing, or even how you're using everything.
    What if I asked you right now what's wrong with my firefighting robot? It uses a 393 and a 4017 to put out fires, but it's not spraying the water. What's wrong? Please help!
    Would you be able to answer? That is exactly the amount of information you are giving us. Please expand your explanation and make your questions more specific. We need more information, or else there is nothing more we can do for you.
  18. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Is this a combat Bot?
  19. hgmjr
    Jan 28, 2005
    9,030
    214
    What is the specific goal that has been set for your robot project by your teacher?
    hgmjr
