Help cant get homemade toroid to work
Discussion in 'General Electronics Chat' started by nissan20det, Apr 22, 2015.
  1. nissan20det
    Apr 3, 2015
    19
    Hey guys so Im not sure why this wont work.. what am I missing? Ferrite core, 30 gauge about 100turns with 10 turns of 24 gauge. Powering with 120v A/C (U.S.A.) transformed to 19.8v A/C 60Hz... I have nothing hooked up after this I am just trying to test output with DMM?I get no freq. Or voltage. Either way I hook this up... step up or down.??? 20150422_211843.jpg
  2. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    Unsuitable material for 60Hz?
    Max.
  3. dl324
    Distinguished Member
    Mar 30, 2015
    3,376
    651
    Is the 24 gauge wire insulated?
  4. ScottWang
    Aug 23, 2012
    4,925
    777
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    If the TS is seriously comptemplating energising either winding direct from 120V mains supply I'm puzzled as to why this thread hasn't been locked.
  6. ScottWang
    Aug 23, 2012
    4,925
    777
    He is not connected directly to the Mains -- Powering with 120v A/C (U.S.A.) transformed to 19.8v A/C 60Hz.
  7. Hypatia's Protege
    Mar 1, 2015
    2,844
    1,309
    At considerable risk of sounding a Pollyanna, I assume you are contemplating application of 19.8V (as opposed to 120v) to the 100 turn winding on the toroidal form...
    Anyway, the short answer is that the magnetic properties of ferrite (or iron powder) material is not suited to magnetic components operating at SLF/ELF...
    Best regards
    HP
  8. crutschow
    Mar 14, 2008
    13,475
    3,362
    The core may be saturating, but you should see something. :confused:
  9. Hypatia's Protege
    Mar 1, 2015
    2,844
    1,309
    The (toroidal transformer's) primary reactance may be so low at 60hz that he is effectively 'shorting out' his power supply xfmr...
    Best regards
    HP
  10. jpanhalt
    Jan 18, 2008
    5,699
    909
    Where's the power to the primary?
    John
  11. DickCappels
    Aug 21, 2008
    2,756
    666
    There are connections to the primary which is the thinner wire. The heavy wire with only 10 turns is the secondary.
  12. alfacliff
    Dec 13, 2013
    2,449
    428
    that is very short wire and a small toroid. unsuitable for 60 hz, more for rf. primary inductrance too low to hold down current, as well as probably wrong core material. try it with a higher frequency.
  13. Alec_t
    Sep 17, 2013
    5,968
    1,135
    Have you scraped off the enamel from the wire end regions so that there is proper contact with the breadboard sockets?
    OBW0549 likes this.
  14. shortbus
    Sep 30, 2009
    4,088
    1,670
    Don't toroidal "transformers" normally have a wound steel/iron band or strap core for 60 - 50Hz? At least any I've seen data sheets on them do. Ferrite or iron powder cores are for high frequency transformers.
  15. Reloadron
    Jan 15, 2015
    1,042
    268
    That would be my question also. Hard to tell but the AWG 24 looks to be just bare copper wire shorting itself out. While as built it may not be an ideal transformer I would expect to see something on the secondary.
    Ron
  16. Roderick Young
    Member
    Feb 22, 2015
    408
    168
    I like that theory. A quick way to check would be to put the DVM across the 100-turn primary of your toroid while voltage is applied, to see if the voltage is still on the order of 19 volts. If the 10-turn side is connected to 19 volts, I would certainly expect your input transformer to be overloaded.
    Never hurts to re-check with your multimeter, I guess.
    I unwound a toroidal transformer intended for 50/60 Hz. I don't know whether it was ferrite inside - might have been soft iron. If it was laminated strips, I couldn't see it through the paint. http://pididu.com/wordpress/solarbike/deconstructing-a-toroidal-transformer/
    What I noticed in this case is that the 8.5 volt winding had about 130 turns, so you're in the right ballpark, if your torroid is soft iron. If it is, in fact, ferrite, then the inductance per turn-squared is likely to be much lower, and there's an even greater chance of saturating your core. But even if the core is saturating, you should be seeing some output. That's why I like the idea that you're overloading the input supply that Hypatia suggested.
  17. ian field
    Oct 27, 2012
    4,447
    791
    The ferrite material toroids are made of won't work at 60Hz.
    You need to chop the energising current at say; 20 - 50kHz or so.
    You need a rectifier/reservoir for your 19.8VAC, after that; one of the off the shelf SMPSU chips may be the easy way to go.
    You need to read up on things like flyback, buck and push-pull to determine which topology best suits what you want to achieve.
  18. crutschow
    Mar 14, 2008
    13,475
    3,362
    Randomly designed transformers seldom work as desired. :rolleyes:
    KLillie and hexreader like this.
  19. nissan20det
    Apr 3, 2015
    19
    Lol lots of replys wow...lol
    okay yes the bare wire is insulted.
    Yes I did burn enamel off and sanded it down.
    yes the mains where connected when I tested it.
    .178Ohm 24g .4978ohm 30g
    So after I posted this about ten mins later I did get a reading at least. 19.8vdc in currnet draw-2.89347amps. Output 60hz at .0096vdc steping up and .0087vdc steping downsame current draw.. and yes this drops my input voltage to the same as output. So im guessing I need much higher freq.
    Can any of you link me to a simple dc chopper schematic. Possibly using a 555. If you guys think freq is my prob.
    So yes possibly need higher freq.?
  20. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    If it was it is probably sulking now?:p
    Max.
    wayneh and Sinus23 like this.
